Sony FX2
Kaikki videoon liittyvä (ei still-kuvausta). Uusi alue, 21.1.2020. Siirretty pari ketjua pohjaksi.
Sony FX2
Sony FX2 julkaistu:
https://www.dpreview.com/news/091862742 ... nouncement
Sony has announced the FX2, a cinema camera built around a full-frame 33MP BSI sensor. Despite its presence in Sony's Cinema line, it's also surprisingly capable as a stills camera – the company says its goal was to have the same photo features as the a7 IV – which could be a sign of even more interesting things to come in Sony's video-focused lineup.
Key Specifications:
33MP BSI CMOS sensor
4K <30p derived from full-width 7K capture
4K <60p with APS-C crop
AI-based autofocus tracking and video cropping modes
Mechanical shutter and stills mode switch
3.68M dot tilting EVF
1x CFexpress Type A/SD slot, 1x SD slot
...variable angle EVF voisi olla aika hyvä lisä meikäläisenkin still-kuvauksiin:
It does, however, add a variable angle EVF with 0.70x magnification and a 33mm eyepoint, which Sony says will let you monitor your video without having to put your eye completely up to it. A loupe-style eyecup, which can be swapped for use with your right or left eye, enhances that experience. It also has a much deeper grip than the FX3 and FX30, and even more custom function buttons, with a new one on the EVF.
