Sony FE 16-35mm F2.8 GM II
Tänään julkaistu...Sony FE 16-35mm F2.8 GM II
https://www.sony.fi/electronics/e-tyypi ... sdetails_1
https://www.dpreview.com/news/316948009 ... m-f2-8-gm2
https://www.youtube.com/watch?v=bc0DjcMyJ4o
Re: Sony FE 16-35mm F2.8 GM II
Gyllä vain, ja arvostelumenestys:
https://www.ephotozine.com/article/sony ... view-36629
ePhotozine tested the new lens and concluded:
Smaller, lighter, better in many ways especially sharpness, the FE 16-35mm f/2.8 GM II lens is Sony at the top of their game. The resolution is still well up to the most recent, higher pixel counts from camera bodies such as the 60MP A7C R used in this review. Handling is superb, focusing fast and virtually silently and really the only downside to all of this is the price. However, after probably many years of use the price itself will soon be forgotten and what will remain will hopefully be some very fine images and a lens that still delivers the goods.
The Sony FE 16-35mm f/2.8 GM II lens is therefore Highly Recommended.
SonyAlphaBlog also tested the lens and writes:
The Sony FE 16-35mm F2.8 GM II is the best in all domains except resistance to flare
Compared to the GMI , the GMII is smaller, lighter, is a little bit sharper in the corners wide open, better at 35mm, has shorter min focusing distance so more macro capabilities, has better ergonomics specially for video with its aperture ring, no focus breathing (GM I had one) and being parfocal, it has less vignetting & a faster AF
https://sonyalpha.blog/2023/10/18/sony- ... 2-8-gm-ii/
Tää lasi aiheuttaa kyllä aika sietämätöntä ostokutinaa. Ykkösversio on niitä harvoja laseja, joilla kuvatut dokkarit ja uutiskatsaukset tunnistaa piirtotyylistä. Se kuva on vaan niin elävän näköinen. Ykkösen kontrastissa oli paikoin parantamisen varaa ja jos tällä asia hoitui, niin tervetuloa vaan.
Joo, siinä olis kyllä erittäin kiva jos viitsis investoida...
Ois kyllä erittäin kiva. Onneksi hinta hillitsee ostohaluja.
Väliin pitäisi laittaa aika kasa vaikka möis noi nykyiset Samyangin 18, Batis 25 ja Sony 35/1.8..
Taiampa jatkaa vaan noilla kiinteillä tästä eteenkin päin..
Sopivia suotimia etsin ja amatöörinä kyselen, että onko kenelläkään kokemusta Urthin magneettisista 82 mm suodattimista?
Vai rajaako vinjetointi käyttöalueen esim. 20-35 mm?
Magnetic Essentials Filter Kit Plus+ includes snap-on
UV Plus+
CPL Plus+
ND8 Plus+
ND1000 Plus+
UV Plus+
CPL Plus+
ND8 Plus+
ND1000 Plus+
Ei kannata ampua itseään jalkaan. Kaikki mitä ei kierretä tiukkaan, vuotavat jostain sitä valoa. Jos ei nyt, niin viimeistään jonkin ajan käytön jälkeen kun alkaa klappia olemaan. Varsinkin kun mennään tonne ND1000+ luokkaan. Kierrät tai sit ihmettelet flarei just siinä Kivassa Kuvassa.
Mulla kun ei ole näistä kokemusta niin onko näissä vain flätti magneettinen pinta toista vasten?Maffer kirjoitti: ↑Heinä 10, 2024 12 : 10 Ei kannata ampua itseään jalkaan. Kaikki mitä ei kierretä tiukkaan, vuotavat jostain sitä valoa. Jos ei nyt, niin viimeistään jonkin ajan käytön jälkeen kun alkaa klappia olemaan. Varsinkin kun mennään tonne ND1000+ luokkaan. Kierrät tai sit ihmettelet flarei just siinä Kivassa Kuvassa.
No näin oli Haidan magneettihimmelissä vuosia sitten. Voihan niitä itse yrittää jollain huovalla vielä parantaa. Kyllä se suodin loksahtaa vähän kuin korkkina pulloon, mut kakkia voi jäädä reunojen väliin ja kyll joku 10min valotus ilta-auringossa on aika brutaali sille onko tiivis vai ei.
