Petzval 80.5mm F1.9 Mark II, Bokeh Control
Petzval 80.5mm F1.9 Mark II, Bokeh Control härveli testissä!
https://sonyalpha.blog/2020/10/08/petzv ... h-control/" onclick="window.open(this.href);return false;
Conclusion
The Lomography Petzval 80.5mm F1.9 Mark II Bokeh Control (499 euros) is an very nice Art lens and an excellent complement to the Petzval 55mm F1.7 MkII
In general “Art lenses” have a very poor sharpness, a vintage color rendition and some re-edition of vintage lenses are sold for crazy price (Around 1000 euros for Meyer Optik Lenses)
Here Lomography has found a very good alchemy with
A superb soft and creamy background blur
A Swirly bokeh effect you can adjust
Very nice Bokeh Balls
A very good and natural color rendition
A good to excellent sharpness in the centre
Of course the lens is not perfect
It is not available in E mount directly (you need an adapter) whereas the Petzval 55mm F1.7 MkII is available in E mount. Compared to it it is much bigger and heavier
It will very difficult to focus outside of the centre and only 25-35% of the image will be sharp
It is not a generalist lens you can use everyday
The Waterhouse aperture / and Bokeh control are options you will not play often with
Globally for portrait, object details (flowers..) the lens is providing superb and unique results plenty of poetry
Also for video the lens is capable of producing subtle dreamy atmosphere while retaining plenty of details on your main subject
Highly recommended
Huom! Tää on Canon EOS (EF) mountilla, eli sovitetavissa adapterssila myös muihin peilittömiin!
Re: Petzval 80.5mm F1.9 Mark II, Bokeh Control
Mikä kolo tossa obiskan rungossa on? Kaikki hiekka ja skeida menee siitä sisään. Ei jatkoon. Ei sitten 500€ hintaan saatu tommosia vahinkoja eees putken alapuolelle.
Siitä voi tunkea erillaisia himmenninkiekkoja sisään!
Näitä leluja ostaa elämänsä suunnan menettäneet eläkeläiset tai bipolaariset wannabetaiteilijat, jolla ei oma mielikuvitus riitä kuin siihen, että peiton alla maatessa osaa kuvitella sitä ihailun määrää, kun julkaisee facebookissa tällaisella viritelmällä otetun "uniikin" ja "taiteellisen" valokuvan.
Ei jatkoon. Hankkikaa elämä ja jättäkää tällainen jäte kauppaan.
heikunkeiku T71, mieti huikkasen mitä skriivaat. Mitä bibolääriset, mielenterveydeltään epävakaat kanssaimmeiset liittyvät tälläiseen puuhasteluun optiikan kanssa??!!
Jos joku saa inspistä, iloa tai jopa hyötyä siitä, että voi taiteilla erilaisten himmennin aukkojen kanssa, niin sehän on ihan harmitonta touhua.
esim. ton kyseisen linkin arvostelija/testaaja jopa tykkäsi tästä erikoisuudesta.
temama kirjoitti:heikunkeiku T71, mieti huikkasen mitä skriivaat. Mitä bibolääriset, mielenterveydeltään epävakaat kanssaimmeiset liittyvät tälläiseen puuhasteluun optiikan kanssa??!!
Hyvin harva täysjärkinen lyö 500 euroa riihikuivaa tällaiseen yhden hitin leluunvehkeeseen.
Ymmärrän toki, että moni eläkeläinen ja mielenterveysongelmainen (joka tällaiseen kusetukseen saattaisi sortua) on yksinäinen ja tällainen jännän näköinen objektiivi auttaa murtamaan jäätä ja tuomaan mielihyvää avautuvan keskustelun kautta, mutta kun samaan lopputulokseen ja parempaankin pääsee ostamalla vanhoja hienoja objektiiveja, jotka ovat jossain odottamassa sitä uutta omistajaa ja niitä ei tarvitse varta vasten valmistaa siksi, että joku haluaa bokehpallukkansa vaikka hakaristin muotoisena tai sydämenä tai miten nyt haluaakaan, kun siihen kyllästyy jo muutamassa kuvassa ihan jokainen, paitsi ehkä joku elämäntapanatsi tai epävarma 11v heppatyttö Huittisista.
Tämä objektiivi on tekemällä tehtyä rahastusta, tätä nykylomografiaa, jossa otetaan rahat pois niiltä ihmisiltä, joilla on taiteilijaunelmia, mutta ei riittävästi omaa mielikuvitusta, rohkeutta tai potentiaalia.
Kyl mä vähän T71:n linjoilla tässä. En niin hirveästi näe itelle käyttöä, tai siis en ollenkaan, mutta jos se myy, on siinä silloin järkeä. Bisnes on bisnestä.
Joo, onhan tuo vähän sellaista ähräämistä, toisaalta en missään nimessä tuomitse jos joku tykkää tosissaan kuvata näillä. Ainakaan se jälki ei ole mitään digiefektejä vaan ihan aitoa tavaraa.
Tässä tuloksia omasta 40€ viritelmästä (modattu Helios 58/2, himmentimenä sydämmen muotoinen levy...
Sydämmellistä Isänpäivää kaikille ;-)
KuvalovePic1 by Aika Arska, on Flickr
KuvalovePic3 by Aika Arska, on Flickr
KuvaovePic6 by Aika Arska, on Flickr
