Päivitin juuri uusimman firmwaren Sigma MC-11 adapteriin. Ja kaikki näyttäisi pelaavan hyvin.
Eli uusin Firmware Versio 1.08 tuli tässä hiljattain, jos joku ei ole vielä huomannut. Ainakin Sony A9 omistajien kannattaa päivittää, mutta tämä uusin v. 1.08 ilmeisesti auttaa myös A7 (ja A6xxx) sarjalaisten kanssa, varsinkin joidenkin objektiivien kanssa...Tässä vähän listausta Sigma MC-11 firmware versioista:
[ MOUNT CONVERTER MC-11 | CANON EF - E ]
Firmware Version 1.08
It corrects the phenomenon that AF does not operate properly when some lenses that are not compatible with the MC-11 are attached.
Firmware Version 1.07
It has become compatible with the SIGMA 14mm F1.8 DG HSM | Art and the SIGMA 24-70mm F2.8 DG OS HSM | Art.
It has become compatible with the FF High Speed Prime Line SIGMA 14mm T2 FF (EF) and the SIGMA 135mm T2 FF (EF).
Firmware Version 1.06
It has become compatible with the 100-400mm F5-6.3 DG OS HSM | Contemporary (Firmware Version 1.01) lens.
Firmware Version 1.05
It has become compatible with the 24-105mm F4 DG OS HSM | Art(Firmware Version 1.02) lens.
It has become compatible with the 17-70mm F2.8-4 DC MACRO OS HSM | Contemporary(Firmware Version 1.03) lens.
It has become compatible with the 18-200mm F3.5-6.3 DC MACRO OS HSM | Contemporary(Firmware Version 1.02) lens.
It has become compatible with the 18-300mm F3.5-6.3 DC MACRO OS HSM | Contemporary(Firmware Version 1.01) lens.
Firmware Version 1.04
It has become compatible with the 135mm F1.8 DG HSM | Art and the 100-400mm F5-6.3 DG OS HSM | Contemporary lenses.
It has become compatible with the Cine Lenses;
・SIGMA 20mm T1.5 FF (EF), 24mm T1.5 FF (EF), 35mm T1.5 FF (EF), 50mm T1.5 FF (EF), 85mm T1.5 FF (EF) from FF High Speed Prime Line.
・24-35mm T2.2 FF (EF) from FF Zoom Line.
It has become compatible with the SIGMA 18-35mm T2 EF mount and the 50-100mm T2 EF mount Cine lenses from High Speed Zoom Line.
It is fully functional with the 12-24mm F4 DG HSM | Art, the 500mm F4 DG OS HSM | Sports and the 85mm F1.4 DG HSM | Art lenses.
It has reduced the startup time between turning on the camera and taking an image by not initially driving the focus when the camera is turned on.
When lenses with Optical Stabilizer (OS) function that are not fully compatible with the MC-11 are attached with the MC-11 and mounted on a camera which incorporates a stabilizer unit, it enables the camera's stabilizer unit to be turned off and the lens's OS function to be turned on and off.
It has improved the AF accuracy of Canon EF lenses that are not fully compatible with the MC-11.
It has corrected the phenomenon where the distortion correction figure is not indicated properly in the camera, when the 24-105mm F4 DG OS HSM | Art is attached.
It has improved the following phenomenon that occurs when lenses that are not compatible with the MC-11 are attached and no light is emitted on the MC-11’s LED lamp.
・It does not operate properly on continuous shooting mode.
・In the case of some lenses that incorporate an OS function, when the camera’s power is turned off, it does not respond to any operation for a certain period of time.
・When open aperture is not selected for shooting, the aperture does not return to fully open.
Sigma MC-11 Firmware Version 1.08
