Sigma 24-70mm f2,8 OS Art
https://www.sigmaphoto.com/24-70mm-f28-dg-os-hsm-a" onclick="window.open(this.href);return false;
Fast, constant-aperture zoom workhorse upgraded to the exacting standards of the high performance Sigma Art series.
Lens Construction 19 Elements in 14 Groups
Angle of View 84.1-34.3º
Number of Diaphragm Blades 9 (Rounded)
Mininum Aperture f22
Minimum Focusing Distance 37 cm / 14.5 in
Filter Size (mm) 82mm
Maximum Magnifications 1: 4.8
Dimensions
(Diameter x Length) 3.5 x 4.2 in
Weight TBD
Featuring a brand new OS and highly efficient and fast AF system, the revamped 24-70mm F2.8 Art embodies all the technical qualities and finesse that define the high-performance Sigma Global Vision Art series. Covering a wide range of shooting scenarios, the 24-70mm workhorse DNA includes three SLD (Special Low Dispersion) glass elements and four aspherical elements to reduce chromatic aberration. The 24-70mm F2.8 Art aspherical elements use Sigma’s groundbreaking thicker center glass design and highly precise polishing process, delivering stunning images and bokeh effects. The lens’ purpose-built structure boasts a new metal barrel for optimal durability with TSC composite internal moving components designed to resist thermal contraction and expansion.
Re: Sigma 24-70mm f2,8 OS Art
Semisti mielenkiintoinen, mutta aika ruuhkainenhan tämä kyseinen segmentti on. Itse en ole vielä saanut puhuttua itseäni pois tuosta "alkuperäisestä" Nikonin 24-70/2.8G:stä. Työhevonen, joka hoitaa hommansa hyvin.
