Sigma 14mm f1,8 ART
Sigma 14mm f1,8 ART
Tällainen:
https://www.sigmaphoto.com/14mm-f18-dg-hsm-a" onclick="window.open(this.href);return false;
World’s first F1.8, ultra-wide, full-frame prime lens designed for high resolution cameras; ideal for shooting architecture, astrophotography, documentary and landscapes.
Lens Construction 16 Elements in 11 Groups
Angle of View 114.2º
Number of Diaphragm Blades 9 (Rounded)
Mininum Aperture f16
Minimum Focusing Distance 27 cm / 10.6 in
Filter Size (mm) N/A
Maximum Magnifications 1: 9.8
Dimensions
(Diameter x Length) 3.8in. x 5.0in.
Weight 1,170g/41.3 oz
Debuting the world’s first 1.8 wide-angle lens, the 14mm F1.8 Art incorporates the same groundbreaking aspherical element as Sigma’s critically acclaimed 12-24mm F4 Art. Boasting outstanding image quality from center to edge, the 14mm F1.8 Art features the largest glass mold (80mm) in the industry, offering photographers an ultra-wide prime with virtually no distortion, flare or ghosting. Three lens elements are made with FLD (“F” Low Dispersion) glass, which is equivalent to calcium fluorite in performance, and four SLD (Special Low Dispersion) glass elements, which reduce chromatic aberration. In addition to the great IQ from edge to edge, the new 14mm F1.8 offers a superfast and efficient AF system.
With a minimum focus distance of 10.6 inches at 14mm, photographers can compose incredible close-up shots with expansive background
Re: Sigma 14mm f1,8 ART
Huikea parannus valovoimaan tässä polttoväliluokassa, mutta oispa jännä nähdä tämä vierekkäin Samyangin/Irix:n kanssa että sais käsityksen paljonko isompi tämä sitten oikeasti on. Painoa on ainakin enemmän.
PAP
Viesti Kirjoittaja PAP »
Isompihan se on ilman muuta, painoa näyttäisi olevan 1170g. 20/1.4 painaa vajaan kilon joten ei tuo lisäpainoa tietenkään enää paljoa ole.
Kyllä on valmistajilla kova kisa valovoimaisten ultralaajisten sarjassa ollut pari viime vuotta: Irix 15/2.4, Laowa 12/2.8, Samyang XP 14/2.4 ja nyt Sigman 14/1.8.
Kolmen edellämainitun laatu jo tiedetään joten Sigma joutuu kovaan joukkoon ja todella laadukas täytyy olla että muut päihittää selvästi.
janne.
Viesti Kirjoittaja janne. »
Ei hitto, pitikö pistää pari Sigmaa lihoiksi että saa maailman parhaimman yökuvauslaajiksen omakseen? Toiv. hinta ei karkaa ihan mahdottomaksi.
No ainakin nyt viimeistään Pentaksin arkku on naulattu kun ei tule ikinä versiota K-mountilla...
Maffer kirjoitti:No ainakin nyt viimeistään Pentaksin arkku on naulattu kun ei tule ikinä versiota K-mountilla...
Saaas nähdä, että innostuuko Sigma pikkuhiljaa enemmän Pentaxin K-mountista nyt kun Pentax julkaisi sen uuden version mountistaan (KAF4), missä aukkosysteemi ei vaadi enää sitä fyysistä vipua vaan aukkoa voidaan kontrolloida kokonaan sähköisesti.
Onhan tälläinen syrjiminen suoraan hanurista ja markkinoita vääristävää, jos merkittävä objektiivivalmistaja julkaisee uusia hienoja objektiiveja vain tietyille kameroille...
Mutta jos tämän Sigma täydellä aukolla ei olekaan kovin ihmeellinen (esim. koomaa nurkissa tai muuta epätoivottavaa), niin silloin valovoimaetu muuttuu marginaaliseksi, eikä objektiivi ehkä olekaan enää niin haluttava.
P.s. ja niin, terve taas kaikki foorumilaiset! Parin viikon tauko täältä ei tuntunut missään, ainakaan meikäläisestä. Hyvä vaan ottaa välillä breikkiä.
Viimeksi muokannut aikaarska, Helmi 23, 2017 20 : 16. Yhteensä muokattu 1 kertaa.
Vaikka se olisi vähän "jojo" täydellä aukolla niin hyvin tod.näk. f/2.8 onkin sitten jo priimaa missä muut kilpatoverit vielä yskii rankasti.
Pentaksin tilanne on surkea, julkaisevat jotain 50mm 1.4 lasin uusia versioita kun laajispuoli on täysin rempallaan ja teletkin vuodelta jeesus.
tn1krr
Viesti Kirjoittaja tn1krr »
aikaarska kirjoitti:
Saaas nähdä, että innostuuko Sigma pikkuhiljaa enemmän Pentaxin K-mountista nyt kun Pentax julkaisi sen uuden version mountistaan, missä aukkosysteemi ei vaadi enää sitä fyysistä vipua vaan aukkoa voidaan kontrolloida kokonaan sähköisesti.
Syrjivää? Rikkoo YK:n kamerarunkojen universaaleja optiikkaoikeuksia? :D Ihan kuten Sony A Mount on Penaalixin mountti niin vähäisessä käytössä, että ei se vaan ole Sigmalle järkevää liiketoimintaa portata putkia noihin, ainakaan heti. Jos/kun Penoja myydään enemmän niin kyllä se tuki sieltä aikanaan tulee, mutta en pidättäisi hengitystä kun toi järkkärimarkkina ylipäätään sukeltaa edelleen.
TiRy
Viesti Kirjoittaja TiRy »
Ei hemmetti.. Ensimmäistä kertaa olen sormi liipaisimella teenkö ennakkovarauksen ja maksan kermankuorinnan ja alan ensitestaajaksi. Olemassa olevia ARTeja seuranneena en usko, että tätäkään on saatu mitenkään ainakaan täysin kustua. Irix kiinnosti niin kauan, kun näki vinjetoinnin, nykyiseen Samyangiin palaa käämi tarkennuksen osumisen kanssa. Jos tämä on edes tasainen suorittaja vääristymien, vinjetoinnin, terävyyden, tarkennuksen toimivuuden kanssa niin voiko mitään muuta edes toivoa? Yli puolet painavampihan toi on verrattuna Samyanggiin, mutta niinhän esimerkiksi nuo ultrawide-zoomitkin ovat.
Mitäpä arvon raati arvioi hinnaksi?
1600€?
2199e Rajalassa.
TiRy
[/kiinnostus]
:D
akukanka
Viesti Kirjoittaja akukanka »
Jos hinta on kallis 1500+ se saattaa kertoa siitä että sillä tekee jotain ihan 1.8 aukollakin. Alta tonni tarkoittaa näköjään aiempien 20 ja 24 perusteella sitä että täydellä aukolla kulmat vinjetoi sen 3 aukkoa ja tähdet on lentävän linnun muotoisia.
-MH-
Viesti Kirjoittaja -MH- »
Keskustelin juuri erään kauppiaan kanssa. Kuuleman mukaan 14mm tulee olemaan kallein Art-lasi. Hinta tulee sijoittumaan 1 500 - 2 000 eur väliin. Hinnat kaiketi julkistetaan maaliskuun lopussa, toimitukset sitten myöhemmin. Katsotaan miten tämä realisoituu, mutta todennäköisesti, jotain tuon hintaista odotettavissa.
Varteenotettava vaihtoehto tälle on Samyangin uusi 14 mm f/2.4, jossa edellisen f/2.8 mallin puutteet on korjattu. Samyang 14 mm f/2.4 toimitukset alkavat viikolla 10.
Viimeksi muokannut -MH-, Helmi 27, 2017 16 : 30. Yhteensä muokattu 1 kertaa.
PAP
-MH- kirjoitti: Varteenotettava vaihtoehto tälle on Samyangin uusi 14 mm f/2.4, jossa edellisen f/2.8 mallin puutteet on korjattu. Samyang 14 mm f/2.4 toimitukset alkavat viikolla 10.
http://gippslandimages.com.au/samyang-x ... ns-review/
http://gippslandimages.com.au/samyang-x ... oma-tests/
RT--
Viesti Kirjoittaja RT-- »
PAP
Luulisi että sekaan olisi eksynyt edes yksi tähtitaivaskuva varsinkin kun morkulaa kaupataan astrokuvaajille ykkösvaihtoehtona.
Kaikki samplethan on aina kuvattu auringonpaisteessa myötävaloon. Ihan objektiivista, kamerasta tai kuvaajasta riippumatta. Ihan sama, kun joku ostaa uuden kameran ja postaa tänne samplen tyyliin "hyvää kuvaa pukkaaa xxx:llä". Tuollaista jälkeä saa aikaiseksi millä tahansa 2-3 vuoden aikana julkaistulla kameralla tai puhelimella.
Nämä ovat vähän tällaisia "Tämä on kamera/objektiivi. Sillä saa kuvia". Really? No shit!
janne.
näkeehän noista paljonkin, jos vain osaa katsoa.
esim. tästä kuvasta huomaa kuinka syväterävyyslaue ilmeisesti on tyypillisesti laajiksille tuplaween muotoinen. äärinurkka on molemmilla puolilla kuvaa terävämpi kuin alue nurkan ja keskustan välillä; sama ilmiö näkyy parissa muussakin kuvassa. kentän kaarevuutta voi ihmetellä myös tästä kuvasta. tästä kuvasta taas näkee että täydellä aukolla pistemäiset kohteet saavat siivet ympärilleen, kun kirkkaat kirjaimet tummalla taustalla leviävät taustan päälle.
Enpä jaksa piippailla noita 1:1.
