torwinen
Viesti Kirjoittaja torwinen »
Sonilla on pasmat sekaisin. Sori pitkä lainaus koskien uutta 85mm 1.8 objektiivia.
https://www.dpreview.com/samples/434879 ... le-gallery" onclick="window.open(this.href);return false;
Of particular interest is our observation that this lens, currently, focuses wide open* on an a7R II (or, technically, opens up to F2 if you've selected an aperture smaller than wide open). This addresses one of our largest complaints with recent Sony lens releases that focus stopped down, often slowing focus in low light or forcing otherwise capable phase-detect AF systems to revert to contrast detect-only. It appears that, at least for now, Sony's recent 100mm STF and 85mm F1.8 lenses address this issue, and without an image cost to boot
Oddly, the same doesn't hold true on other Sony bodies: the lens focuses stopped down at the shooting aperture on an a7 II, a7S, and a6300/6500. Oddly, this sometimes leads to slight front-focus at smaller apertures on those cameras, though it's not a huge deal as the focus shift is often masked by the increased depth-of-field. It's interesting from an academic standpoint though - as focusing at the selected aperture should increase focus accuracy, not decrease it. We have our hypotheses, but for now, we've reached out to Sony for comment.
kohan
Viesti Kirjoittaja kohan »
Onko tuossa google translate japanista englantiin vai millä tuon selittää.
torwinen
kohan kirjoitti:Onko tuossa google translate japanista englantiin vai millä tuon selittää.
Ei tuolle ole mitään selitystä.
tn1krr
Viesti Kirjoittaja tn1krr »
torwinen kirjoitti: Oddly, the same doesn't hold true on other Sony bodies: the lens focuses stopped down at the shooting aperture on an a7 II, a7S, and a6300/6500. Oddly, this sometimes leads to slight front-focus at smaller apertures on those cameras, though it's not a huge deal as the focus shift is often masked by the increased depth-of-field. It's interesting from an academic standpoint though - as focusing at the selected aperture should increase focus accuracy, not decrease it. We have our hypotheses, but for now, we've reached out to Sony for comment.
Tuo kuulostaa hiukan kuvaamaltani "laiskalta avaamiselta". Normivalossa ei avata ollenkaan ja todella huonossa valossa vain vähän. Esim. vanha A7R tai Nex-7 ei avannut ikinä F/5.6:sta F/4:ää isommalle aukolle. Tämä siis Live View Setting Effect "on" asennossa, "off" asennossa oltiin täydellä aukolla lukkoon saakka AF-S:llä. Tuossa linkitetyssä jutussa kun ei otettu kantaa Setting effect asetukseen, tuossa puhuttiin kai vain Setting Effect on toiminnasta.
torwinen
tn1krr kirjoitti: Tuossa linkitetyssä jutussa kun ei otettu kantaa Setting effect asetukseen, tuossa puhuttiin kai vain Setting Effect on toiminnasta.
Ensimmäisen lainatun kappaleen tekstistä saa kyllä sellaisen kuvan, että kyse on Setting Effect OFF toiminnasta.
tn1krr kirjoitti:
Olenko oikeassa, että tämä koko homma (tiettyjen objektiivien kanssa) vaikuttaa pahimmillaan epäkäytännöllisesti lähinnä silloin kun kuvataan salamalaitteiden kanssa vähävaloisessa paikassa ja halutaan käyttää pientä aukkoa, esim. f/8? ...Eli silloin jos kamera haluaa himmentää valitulle aukolle jo tarkennuksen aikana, se johtaa huonoon AF nopeuteen koska sensorit ei saa kunnolla valoa tarkennuksen suorittamiseen?
Mutta parhaimmillaan tämä Sonyn viritys taas johtaa erittäin täsmälliseen AF tarkennukseen paremmassa valossa - mihin se lienee tarkoitettukin. Ei focus shiftiä.
tn1krr
aikaarska kirjoitti:Olenko oikeassa, että tämä koko homma (tiettyjen objektiivien kanssa) vaikuttaa pahimmillaan epäkäytännöllisesti lähinnä silloin kun kuvataan salamalaitteiden kanssa vähävaloisessa paikassa ja halutaan käyttää pientä aukkoa, esim. f/8? ...Eli silloin jos kamera haluaa himmentää valitulle aukolle jo tarkennuksen aikana, se johtaa huonoon AF nopeuteen koska sensorit ei saa kunnolla valoa tarkennuksen suorittamiseen?
Kyllä tuo haittaa huonossa valossa kuvaamista ylipäätään eli ei tarvitse himmentää sinne F/8 asti. Jengi on valitellut, että F/5.6 ei tahdo tulla mallivalojen kanssa joissain oloissa touhusta mitään. Aiemminhan on ollut mahdollista vanhoilla rungoilla laittaa Setting Effect off jos tuntuu että haluaa lisää valoa AF:lle (vaikka sitten focus shift:in riskillä), A7R II + GM 24-70 tai GM 85 tätä vaihtoehtoa ei ole. Itse en about koskaan kuvaa AF:llä F/5.6:sta pienemmällä aukolla, mutta kyllähän toi Setting Effect off oli vanhoilla "laiskan avaamisen" rungoilla ahkerassa käytössä aukon ollessa F/4 tai pienempi.
aikaarska kirjoitti: Mutta parhaimmillaan tämä Sonyn viritys taas johtaa erittäin täsmälliseen AF tarkennukseen paremmassa valossa - mihin se lienee tarkoitettukin. Ei focus shiftiä.
Kyllä, mutta esim. A7R II + Batis 85 avaa fokusointiin ja silti välttää focus shiftin, koska AF osaa hoitaa tämän tekemällä pienen CDAF-iteraation vielä himmentämisen jälkeen. Tämä ominaisuus ei ole mikään "puolensa ja puolensa" tradeoff vaan selkeä heikkous verrattuna moniin muihin natiivilaseihin.
kohan
tn1krr kirjoitti: Kyllä tuo haittaa huonossa valossa kuvaamista ylipäätään eli ei tarvitse himmentää sinne F/8 asti. Jengi on valitellut, että F/5.6 ei tahdo tulla mallivalojen kanssa joissain oloissa touhusta mitään. Aiemminhan on ollut mahdollista vanhoilla rungoilla laittaa Setting Effect off jos tuntuu että haluaa lisää valoa AF:lle (vaikka sitten focus shift:in riskillä), A7R II + GM 24-70 tai GM 85 tätä vaihtoehtoa ei ole. Itse en about koskaan kuvaa AF:llä F/5.6:sta pienemmällä aukolla, mutta kyllähän toi Setting Effect off oli vanhoilla "laiskan avaamisen" rungoilla ahkerassa käytössä aukon ollessa F/4 tai pienempi.
Lisäksi AF-C kaikilla optiikoilla ei toimi f8 jälkeen oli Setting Effect on tai off.
Täällä taas muutama sämppeli otsikon kameroista videokäytössä.
A7S:
http://www.digicamera.net/keskus/viewto ... t=12747477" onclick="window.open(this.href);return false;
A7SII:
http://www.digicamera.net/keskus/viewto ... t=12747484" onclick="window.open(this.href);return false;
Jyrki Auti
Viesti Kirjoittaja Jyrki Auti »
Jaahas Sonyn ominaisuuksia/vikoja pitäisi taas puntaroida. Eli Metabonen + Canonin 100 tai 70-200/2.8 tekee telepäässä isolla aukolla ja nopeilla suljinajoilla +4000-8000 sulkimella kuviin mustan yläreunan 1/4 osalle, onko ominaisuus vai verhosuljin paskana voisiko joku kokeilla.
Af-c:n toimimattomuus pienemmällä aukkolla kuin f8 taitaa myös olla ominaisuus (sahaa paikallaan kiinteässä kohteessa).
Voi tätätä riemua taas.
Onko sulla päällä EFCS? Se ei toimi tollasilla suljinajoilla enää. Jossain 1/1000 menee raja että sitä kannattaa käyttää. Lisäksi se paskoo bokehin.
Jyrki Auti
Suuri Kiitos, päällähän se oli, testasin ilman ja mustaa ylärenaa ei ainakaan nyt pikaisella testillä näyttänyt tulevan.
Mitäköhän muita asetuksia jää kuvatessa väärään asentoon, ton matopurkin mukanahan täytyy ruveta pitämään jonkinlaista tsek"in listaa.
Jalustan kuulapäässä olen jo kauan pitänyt merkkilappua muistuttamassa vakaajasta:)
No jep. Lisäksi se kameran oma patteri voi tyhjentyä jos akkua ei vaihda tarpeeksi sukkelaan kylmässä. Eikä se lämpimässäkään ikuisuuksia kestä. Sen jälkeen ainakin saa hetken miettiä mites ne säädöt menikään ;D
Jyrki Auti kirjoitti:Jaahas Sonyn ominaisuuksia/vikoja pitäisi taas puntaroida. Eli Metabonen + Canonin 100 tai 70-200/2.8 tekee telepäässä isolla aukolla ja nopeilla suljinajoilla +4000-8000 sulkimella kuviin mustan yläreunan 1/4 osalle, onko ominaisuus vai verhosuljin paskana voisiko joku kokeilla.
voih&eihh. on se kamalaa sonylta taas kun caanonin ja jonku metaboonesin värkit ei toimi! heti sonia syyttämässä, vaikka oliskohan kysymyksessä ihan kuuluisa user errorssi??!! ettei vaan olis SÄeVS päällä?? Elikkäs sähkönen etuverhon suljin...
kohan
Uusi firmis Metabones adapterille v0.56 ladattavissa
http://www.metabones.com/article/of/EF-E_Firmware_Win" onclick="window.open(this.href);return false;
Onko muilla ongelmia suojausten kanssa?
kohan kirjoitti:Uusi firmis Metabones adapterille v0.56 ladattavissa
apuuva! kinuskit tulee ja kaappaa meitin adapterssit caiberviiruksilla!!! hybridiWar, sitä se on.
juuh, ei tullut varoitusta minulla.
kohan
temama kirjoitti: juuh, ei tullut varoitusta minulla.
MacAfee ja Norton 360 Premier on sen verran tarkkoja ettei Metabones kelpaa. Muillakin näyttää olevan viimeisten päivitysten kanssa murheita.
kohan kirjoitti:
meigä luottaa kotomaiseen fsekureen, ei ollut ongelmiua tän kanssa. joskus liika varovaisuus ei välttämättä tarkoita samaa kun hyvä.
ruutu
Viesti Kirjoittaja ruutu »
Troijalainen piipahti kylään vuosia sitten ja sen jälkeen en ole ainakaan ilmaisiin virusturviin koskenut. Tosin noiden maksullisten kanssa kone tarpoo sitten tervassa...
Whig
Viesti Kirjoittaja Whig »
Jotkut tutkat tuosta varoittavat mutta jotkut eivät:
https://virustotal.com/en/file/584a0d63 ... 492285711/" onclick="window.open(this.href);return false;
Flickr
Instagram
