Sony A9, A9II
Re: Sony A9
Ilmeisesti kohta uusi firmis on ladattavissa:
https://sonycamerarumors.net/sony-a9-fi ... -march-25/" onclick="window.open(this.href);return false;
Linkki vie huhuun firmiksen julkaisupäivästä.
Showreel:
https://vimeo.com/814152881
Re: Sony A9
Nyt sitä saa 5.0
https://www.sony.com/electronics/suppor ... #/howtoTab" onclick="window.open(this.href);return false;
Re: Sony A9
kohan kirjoitti:Nyt sitä saa 5.0
Uskomaton päivitys! Älyttömän laaja, jotkut käyttäjät maailmalla jo illakoi, että tuntuu, että ovat saaneet uuden kameran 'ilmaiseksi"
https://www.dpreview.com/forums/post/62472112" onclick="window.open(this.href);return false;
'ihan pikku listaa vaan';
https://www.sony.com/electronics/suppor ... s/00220555" onclick="window.open(this.href);return false;
mm;
- Highly accurate automatic detection and tracking of subjects / Tracking, Tracking On, Touch Tracking
- Evolution of Eye AF function / Face/Eye AF Set.
A Face/Eye AF Set. function evolved from the conventional Face detection function has been provided
- Touch pad function / Touch Pad Settings
A touch pad function has been provided that lets you move the focusing frame position by dragging your finger on the monitor like a touch pad.
- Increased focal plane phase detection AF accuracy and expanded application range
The AF algorithm has been further brushed-up to improve the focal plane phase detection AF accuracy during AF-C and continuous shooting. Performance has also been enhanced in environments with lower light
- Increased number of contrast AF frame divisions
The number of contrast AF frame divisions has been increased from the current 25 frames to 425 frames. This enables highly accurate AF even in low-light
- Display only frequently used focus area types / Focus Area Limit
- Limited ISO display / ISO Setting: ISO Range Limit
You can set the camera so that only frequently used ISO ranges are displayed in the ISO setting screen.
- Display ISO value all the time when recording movies in ISO AUTO mode
- AWB lock function / Shutter AWB Lock, AWB Lock Hold, AWB Lock Toggle
You can select whether or not to lock the auto white balance at the desired timing
- Increased detection accuracy of peaking function and addition of blue peaking color / Peaking Setting
The detection accuracy of the peaking function
- You can select the JPEG picture quality from among Extra fine, Fine or Standard when the still image recording file format is set to RAW & JPEG.
- Support for simultaneous recording of proxy movies / Proxy Recording
Simultaneous recording of 4K movies and low definition proxy movies is supported.
- Support for 1:1 image aspect ratio / Aspect Ratio
The 1:1 image aspect ratio is supported in addition to the conventional 3:2 and 16:9 aspect ratios.
- Zebra function setting method / Zebra Setting
Zebra display and zebra level can be set separately.
- Support for exposure compensation while pressing the shutter button halfway down in still image shooting mode
Exposure compensation can be performed by operating the exposure compensation dial while pressing the shutter button halfway down in auto focus mode.
- Addition of movie recording format XAVC S HD recording settings
60p 25M and 30p 16M have been added to Record Setting.
- Advanced dual slot functionality / Auto Switch Media
- Changing the function of the dial temporarily / My Dial Settings
- Improved usability of function menu settings / Function Menu Set.
- Selection of memory card slot for Memory recall (MR) function that enables to quickly recall camera settings / Select Media
- Support for wired LAN remote control
You can remotely control the camera with a high degree of freedom suited to professional sites via the PC app “Remote Camera Tool”. You can also remotely control an Ethernet connected camera or multiple cameras from this application. In addition, remote control is possible even during FTP transfer, which achieves even higher shooting efficiency.
- Support for smartphone always connected / Ctrl w/ Smartphone
You can set whether or not to always connect the camera to a smartphone. When this function is set to On, once you connect the camera to a smartphone, it will remain connected to the smartphone at all times.
Ja muistakaahan, kohta saman tyyppistä tulee A7III ja A7RIII malleille huhtikuussa!!!
Ja A9 firmware v.6.0 tulee kesällä vielä, eli ne työstää kokoajan uusia ominaisuuksia näille laitteille! Tää on hyvä meinkinki. tyky-tykkään!
https://www.dpreview.com/news/505738901 ... proving-af" onclick="window.open(this.href);return false;
Re: Sony A9
Eläs nyt maffers!! Skriivasin, että tykkään hyvästä meiningistä! Tää pos pöhinä hommassa.Maffer kirjoitti:Tykkäät jostain mitä et tule käyttämään? Melkosta.
ja eihän sitä tiedä, että joskus käyttäisin näitä laitteita kun mun A7Ärrkakosesta aika jättää.
Re: Sony A9
Päivityksen jälkeen aloitat määrittämällä kellonajan, aikavyöhykkeen...temama kirjoitti: Älyttömän laaja, jotkut käyttäjät maailmalla jo illakoi, että tuntuu, että ovat saaneet uuden kameran 'ilmaiseksi"
Seurantatarkennus on älyttömän hyvä vaikka aikaisempikin oli erinomainen. Toimii aina aukolle 16 asti kaikilla tarkennuspisteillä.
Re: Sony A9
Temama on "teamplayer".Maffer kirjoitti:Tykkäät jostain mitä et tule käyttämään? Melkosta.
Re: Sony A9
Antaa kaverin tykätä jos tykkää. Mitäpä se keneltäkään on pois? Mieluummin muutenkin lueskelen positiivista fiilistelyä kuin jatkuvaa negailua. Negailu kuitenkin täällä on vallitseva tapa. Toisaalta sitä se on lähes kaikkialla netissä, mikä on ihmeellinen homma jo sekin sinällään.
Showreel:
Re: Sony A9
nonniin kaiffarit, tattista vaan, mutta kyllä kun vetää huikkasen kieliposkessa huumorilla tätä elämää, niin jaksaa 100x paremmin! ehken nää mun sony-hehkutukset &ketkutukset menee ajoittain yli, sorry siitä. sitä on niin helppo innostua.
Mutta toi positiivinen pöhinä. Se on just siitä, kyllä sitä huomaa esim tuolla vaalikojuilla silloinkun porukoilla on positiivinen pössis ja silloin kun sitä ei ole! pieneistä jutuista kiinni.
Mut tärkeimpiin asioihin. Tän uuden firmware päivityksen saralla on tosiaan positiivinen pössis! lol-likkata-ta!
Erittäin hyvä taktiikka Sonylta tällä kertaa. Ne tiesi mihin uusien peilittömien hardware pystyy (A7III, A7RIII ja A9), mutta huippuunsa edistyksellisille toiminnoille ja hieromisille oli pakko jättää vielä aikaa kehitystyölle. Ja nyt se sato valmistuu!
Minusta tälläinen toimintatapa voisi yleistyä enemmänkin tulevaisuudessa. Eli kameran laiteohjelmistotuen jatkuminen ja kehittäminen olisi enemmän sääntö kuin poikkeus.
Koska sehä tiedetään,e ttä mikään ohjelmisto ei ikinä ole täydellinen ja valmis. Nää kamerat on nykyisin kuin pieniä tietokoneita, niiden käyttistä voidaan tosiaan kehittää.
Re: Sony A9
Hommaa temis se Sony-boy jostain. Se käy ihan sijoituksestakin. Arvo nousee vuosi vuodelta. On se jännä, kun hyllyssä on tommonen muovipatsas minkä myymällä saa kohta 400mm GM-lasin.
Re: Sony A9
Nin sulla on tuo? On kyllä hyvä kuva, Luuris siinä tekee kunniaa kuin uudestisyntyvälle Feeniks linnulle!Maffer kirjoitti:Hommaa temis se Sony-boy jostain. Se käy ihan sijoituksestakin. Arvo nousee vuosi vuodelta. On se jännä, kun hyllyssä on tommonen muovipatsas minkä myymällä saa kohta 400mm GM-lasin.
https://mjkoski.1g.fi/kuvat/Luuranko/Pl ... pg?img=ful" onclick="window.open(this.href);return false;
Kyllä mä olen yrittänyt löytää tollasta netistä ja muutamista divareistakin stadista, mutta ongelma tosiaan hinta. Vähän rikkinäisen voi saada jopa alle 200€, ja nyt markkinoille on tullut jonkunsortin piraattikopioita figuurista, niitä saa alle satasen, mutta enhän mä sellaista.Mieluummin vaikka vähän rikkinäinen, mutta aito se täytyy olla!
Re: Sony A9
Kyllä kyllä. Ihan ehta 1900-luvun puolesta välistä ja risat.
Re: Sony A9
Kuten tiedät niin onhan se pois jos kerran Sony.nsamppa kirjoitti:Antaa kaverin tykätä jos tykkää. Mitäpä se keneltäkään on pois? Mieluummin muutenkin lueskelen positiivista fiilistelyä kuin jatkuvaa negailua. Negailu kuitenkin täällä on vallitseva tapa. Toisaalta sitä se on lähes kaikkialla netissä, mikä on ihmeellinen homma jo sekin sinällään.
Tuo oli kyllä taas parasta pitkään aikaan, ei saa olla innoissaan jostain ominaisuudesta jota ei tule itse toisen mielestä käyttämään. Sony kehittyy, Maffer ja nämät muutamat muut, ei koskaan.
Re: Sony A9
A9 taitaa olla sensorin ja laskentatehonsa puolesta se jolla testataan tulevaisuuden tarkennussoftia. Mielenkiinnolla odotan urheilukuvaajien kokemuksia joukkuelajien kuvaamisesta ja AI Tracking toiminnasta pelin tiimellyksessä.
Tietenkin ensi kesän kasvontunnistus ja Eye AF eläimille vaatii varmasti valtavan taustatyön eri lajien ymmärtämiselle. Lajitunnistusta ja datan liittämistä EXIF tietoihin odotellessa.
Re: Sony A9
Vähän epäilen miten tuo lajintunnistus voisi toimia, kun joku googlen kuvahaku luulee jokaista kameraa koskevaa kuvaa Canonin 70-300 milliseksi. "Paras arvaus".kohan kirjoitti: Tietenkin ensi kesän kasvontunnistus ja Eye AF eläimille vaatii varmasti valtavan taustatyön eri lajien ymmärtämiselle. Lajitunnistusta ja datan liittämistä EXIF tietoihin odotellessa.
Mutta on tuo kieltämättä kiehtova ajaus, että kamera alkaisi äkkiä toimimaan kuin ihan uusi malli. Mullakin tuo A7R3 eye af sahaa missä sattuu ja lähes kaikki lasten synttärisankarista otetut kuvat oli tarkentuneet siihen taaempaan silmään. Sehän toimii vähän huonosti, jos kohde katsoo viistoon ja se taaempi puoli on se terävä.
Mutta toisaalta pakkohan se on uskoa, että se on vain kökön koodin syytä, että A7R3 kosketusnäyttö on sysipska viritelmä. En tiedä mitä sieniä japaninmaassa on vedetty, että tuota kehdataan kutsua kosketusnäytöksi. Jospa se alkaisi yhdessä yössä toimia. Harras on tämä toive, vähän kuin lottovoitto, joka ei koskaan osu, mutta sinnikkäästi uskomalla unelma elää ja voi hyvin... ja vie köyhien rahat.
Re: Sony A9
Heitin tuon lajitunnistuksen vain ikään kuin osoittamaan kehityksen suuntaa. Toimivana piirteenä se vaatisi suuren määrän dataa joka ei mahtuisi kameran kuoriin mutta voisi olla sellainen "kiva saada" ominaisuus.T71 kirjoitti:Vähän epäilen miten tuo lajintunnistus voisi toimia, kun joku googlen kuvahaku luulee jokaista kameraa koskevaa kuvaa Canonin 70-300 milliseksi. "Paras arvaus".kohan kirjoitti: Tietenkin ensi kesän kasvontunnistus ja Eye AF eläimille vaatii varmasti valtavan taustatyön eri lajien ymmärtämiselle. Lajitunnistusta ja datan liittämistä EXIF tietoihin odotellessa.
A7R3 saa ensi kuussa päivityksensä tarkennukseen ja sitä odotellessa.
Re: Sony A9
Kirjoittamalla googleen panorama animal fail saa käsityksen mikä on oikeasti hauskin uusi ominaisuus kameroissa vuosiin. Mutta odotellaan nyt tulisiko omaan runkoon vähän parannusta, kun suoraan sanottuna se on kohta menossa myyntilaidalle, ellei se ala osumaan paremmin.
Re: Sony A9
Mitä optiikoita sulla on kamerassa kiinni kun ei osu.T71 kirjoitti:Kirjoittamalla googleen panorama animal fail saa käsityksen mikä on oikeasti hauskin uusi ominaisuus kameroissa vuosiin. Mutta odotellaan nyt tulisiko omaan runkoon vähän parannusta, kun suoraan sanottuna se on kohta menossa myyntilaidalle, ellei se ala osumaan paremmin.
Re: Sony A9
Poimintoja uuden A9 firmwaren osalta:
https://www.dpreview.com/news/506932395 ... ersion-5-0" onclick="window.open(this.href);return false;
https://www.youtube.com/watch?v=4KbxJ6EbZJE" onclick="window.open(this.href);return false;
https://www.youtube.com/watch?v=sK_wHg4dQKM" onclick="window.open(this.href);return false;
https://www.youtube.com/watch?v=NxT7UMmaQVk" onclick="window.open(this.href);return false;
https://www.youtube.com/watch?v=YkggoheUjpo" onclick="window.open(this.href);return false;
Re: Sony A9
Testasin tänään illan hämärtyessä Sigman MC11 adapteria Canonin EF 100-400 ja EF 200 f1.8+2x. Päivitin MC11 viimeisimmällä firmiksellä ennen testausta.
A9 toimii nyt paremmin kuin ennen 5.0 firmistä. En tiedä johtuuko toiminnan parannus Tracking AF:n algoritmeistä vai kontrastitarkennuksen pisteiden lisäämisestä 25->425. Nyt seuranta toimii koko etsimen alalla reunasta reunaan. Ennen tarkennus toimi vain etsimen keskialalla. Nytkin reuna-alue on myös se missä tarkennus hukkuu helpommin.
Halusin testata heikommalla valaistuksella jotta erot tulevat paremmin esille.
Sonyn oma FE 100-400GM +1.4x toimintaan heikompi valaistus ei vaikuttanut mitenkään. Tarkennus nappaa heti ja pysyy kohteessa niin kauan kuin kohde on ruudulla.
