Kohta se tärähtää uunista ulos!! Aito konstailematon huippulaadukas Sony FE 70-200mm F2.8 GM OSS II, ehkä paras objektiivi lajissaan? Se jää nähtäväksi.
100% reliable Sony 70-200mm f/2.8 GM II lens specs:
It will be 30% lighter then the mark I (just around 1kg)
Plus some other aspects everybody Will be happy about especially paired with A1
it has an aperture ring
The lens will be announced this week on October 13!
Tosi nastaa, että Sony ottanut keveyden huomioon uusissa objektiivijulkaisuissaan!
Heti tämän objektiivin jälkeen julkaistaan Sony A7IV, ja ylläripylläri - sen jälkeen vielä toinen objektiivijulkaisu!!
Elämä on valokuvaajan parasta aikaa!Vîta est tempus optimum homini
When it comes to longitudinal chromatic aberration, overall there are no reasons to complain. A significant number of lenses made of low dispersion glass perform as they should. What's interesting, if you take a closer look at the pictures below you can notice that the aberration is not corrected in a perfect way and the effect is quite original. You can't notice any significant colouring but relatively wide areas before and after the focus are colored yellow on the one side and blue on the other. This effect is rather subtle, difficult to notice in any real-life photos, but it remains noticeable in the photos of our testing chart.
Ja positiivisten asioiden lista pitkä;
Pros:
solid, shapely, lightweight, and weather-sealed casing,
sensational image quality in the frame centre,
excellent image quality on the edge of the APS-C sensor,
very good image quality on the edge of full frame,
sensible correction of longitudinal chromatic aberration,
negligible lateral chromatic aberration,
lack of problems with spherical aberration,
slight vignetting on the APS-C/DX sensor,
very good coma correction,
low astigmatism,
nice out-of-focus areas for a zoom lens,
silent, flash-quick, and accurate autofocus,
very efficient image stabilization.
Ainut mikä mua kismittää enempi niin ilmeisesti on vähän ongelmallinen suorituskyky suoraan vastavaloon.
elmar kirjoitti: ↑Loka 14, 2021 12 : 59
On vaan turhan iso, ei mahdu rungon kanssa pystyssä laukkuun. Optisesti tod.näk. ok, kuten n. 3000 e:n lasilta voi odottaakin.
Tamron 70-180 mm f/2.8 Di III VXD e-mounttiin on silloin hyvä valinta. Pienempi ja painaa vain 800 grammaa. Piirto kuitenkin hyvä, ja hinta. 1190€
Tuon Tamronin vähän aikaa omistaneena voin loihie lausumahan tuosta piirrosta sen verran, että joo, pirun skarppi, mutta siihen ne piirron hyveet sitten jäivätkin.
En ole eläissäni laittanut yli tuhatta euroa tuon huonompaan objektiiviin kuin Tamroniin.
Mutta joo, jollei olisi köyhä räpsijä, tuo uutukainen Sony olisi kyllä melko namu, saaneet tuosta tuollaiseksi valovoimaiseksi vakaajalliseksi vieläpä noinkin kevyen.
Fujilla omistin 50-140mm f2.8:n ja se oli painonsa vuoksi miellyttävä käyttää pienellä peilittömällä ja tuo uusi Sony ei juurikaan ole sitä Fujia raskaampi, muutama hassu kymmenys eroa, joten kyllä nyt on Sony kunnostautunut ja ihan huolella ja luulisi että jo senkin puolesta jengi vaihtaa, siis ne joilla pinkka kunnossa...
EI, vaan “higher than expected demand”, toki. Miljoonat himokkaat loistokkuuteen tottuneet Sonystit haluavat päivittää mark 1 kakoseen, of course! Kohtaa ykösversiota saa edullisesti käytettynä!!
Miksi sitten Lenstipin revikka o melko kaamea huomioiden uusi tuuhea hinta? Nyt o muutenkin hyvä vedota saatavuuteen. Jos joku valittaa miksei saanu mieluista synttäri- tai joululahjaa, voi vaa todeta ettei saa kaupasta tuotetta. Kaikkien aikojen joulusäästäjäiset.
Joo, näkynyt montakin kalliimmalla kuin vaikka Verkkokaupasta saa uuden. Ihmettelen, mutta saahan sitä pyytää ei siinä mitään. Uusi 70-200 vaikuttaisi hienolta peliltä. Harkitsen silti enempi f2-2.8 35-150 Tamronia. Melkeinpä pärjäisi yhdellä lasilla kaikkialle.
