Sony alpha 100:seen uusi firmware saatavana (1.04)
jsonya100
Viesti Kirjoittaja jsonya100 »
Uutena forumilaisena aloitetaan pienellä vinkillä eli Sony alpha 100:seen uusi firmware saatavana (v1.04) täältä. Samalla voi päivittää kameran mukana tulleen Picture Motion Browserin uudempaan versioon.
Photoclup Alphan sivu tiesi kertoa seuraavaa:
Officially this update just adds the 55-200mm lens to the lookups. But it does more. After updating, our A100s will no longer shoot 6 RAW+JPEG frames at 3 fps, which I am pretty sure we managed using the Extreme IV card despite the official spec being 3 frames. They will only shoot three frames regardless of the card speed including Kingston 266X UDMA. Something is slowing down the system for RAW+JPEG. JPEG only shooting remains unaffected - you get continuous until the camera overheats. RAW shooting in sequence is improved, which indicates that the actual buffer to card writing speed is better than Firmware 1.02 which was the last update on our two A100 bodies. I managed 27 frames RAW at 3fps before the camera slowed down, after installing the upgrade. That is exceptional. Focus speed appears to be slightly improved, card writing speed appears to be improved, and subject to further tests, I would guess that JPEG quality has been enhanced or better noise reduction implemented.
