kohan
Firmware 3.20
Viesti Kirjoittaja kohan »
Uutta versiopäivitystä
Toimiikohan hakkeroidun videon tallennusajan kanssa?
Näyttäisi toimivan mutta max aika tarvitsee laittaa uudelleen käyttöön.
This utility updates the ILCE-7RM2 system software to version 3.20, and provides the following benefits:
Improvements over version 3.10:
Allows recording of XAVCS format video with an SDHC card in addition to SDXC card.
Notes:
When an SDHC card is used in XAVC S format over long periods, the recorded movies will be divided into 4GB files. Those files can then be integrated into a single file using the PlayMemories Home software
Shooting movies in XAVC S format requires SD Speed Class 10, UHS Speed Class U1, or faster
When recording at 100Mbps or more, UHS Speed Class U3 is required
Benefits provided by previous updates and included in version 3.20:
Support for additional lenses.
Support for Phase-detection AF
The AF can be used in movie recording mode with the SEL85F14GM
Improves 4K movie recording time when using the vertical grip (VG-C2EM) or when APS-C/Super35mm mode is activated
Improves picture quality
Adds the selectable feature for uncompressed 14-Bit RAW image capture
Adds support to output video via HDMI during use of the Remote Camera Control software (still mode)
Reduces the chance of the camera changing to front focus when shooting certain scenes
Decreases chroma noise when Long Exposure NR is set to Off
Note:The noise does not occur when Long Exposure NR is set to On
Improves continuous shooting at Hi speed
https://esupport.sony.com/US/p/swu-down ... roup_id=24
http://kohan.1g.fi/
kohan
http://kohan.1g.fi/
tn1krr
Viesti Kirjoittaja tn1krr »
kohan kirjoitti:Mitä tämä muutos firmiksessä tekee?
"Adds the selectable feature for uncompressed 14-Bit RAW image capture"
Tuo on noissa "vanhoissa" muutoksissa (Benefits provided by previous updates and included in version 3.20) eli tuo on se 14-bit uncompressed RAW.
Ainut virallinen muutos tässsä uudessa 3.20:ssä vs. versio 3.10 on tuo XAVC S mahdollisuus SDHC:lle.
kohan
tn1krr kirjoitti:
Niinpä, taisi olla vähän niin kuin toiveajattelua että tuolle pakkaukselle olisi tehty enempi vaihtoehtoja.
http://kohan.1g.fi/
kohan
Kokeilin vielä XAVC S 4k videotaltiointia reilun 2h ajan niin yhden tiedoston koko on 87GB. Tämä onnistuu riittävän nopealle SDXC kortille.
Taltiot SDHC kortille (Fat32) tapahtuu ilmeisesti 4GB pätkissä.
http://kohan.1g.fi/
kohan kirjoitti:Kokeilin vielä XAVC S 4k videotaltiointia reilun 2h ajan niin yhden tiedoston koko on 87GB. Tämä onnistuu riittävän nopealle SDXC kortille.
Hyvä tietää kun ostin just edullisesti muutamia nopeita 64GB SDXC kortteja.
Eli ainakin tunti per kortti pitäisi mahtua 4K videota. Oikeastaan yllättävän paljon...
kohan
aikaarska kirjoitti: Hyvä tietää kun ostin just edullisesti muutamia nopeita 64GB SDXC kortteja.
Oliko riittävän nopeita XAVC S videolle?
http://kohan.1g.fi/
janne.
Viesti Kirjoittaja janne. »
kohan kirjoitti:
eihän tuo bitrate ole kuin 100 Mbps eli joku 12 Mt/s mihin yltää rupuisemmatkin kortit.
kohan
janne. kirjoitti:
kohan kirjoitti:
Minulla on videolle SanDisk Extreme PRO 128GB 95MB/s
http://kohan.1g.fi/
Niin tai näin, ehdottoman hyvä kuitenkin tämä päivitys, ettäei tarvitse välttämättä hommata uusi muistikortteja!
http://www.dpreview.com/news/6158853043 ... f=mainmenu
Mutta kun eihän tämä laite edes pysty kirjoittamaan nopeammin kuin 30 MB / sek. Eikös tämä jossain testattukin? tn1krr muistaakseni linkitti asiasta.
tn1krr
Maffer kirjoitti:Mutta kun eihän tämä laite edes pysty kirjoittamaan nopeammin kuin 30 MB / sek. Eikös tämä jossain testattukin? tn1krr muistaakseni linkitti asiasta.
Jes, joku 36-37 MB / sek nää kirjottaa kortille oli mimmonen kortti tahansa. Sisäisen USB2:n päässä lienee toi korttipaikka eli ei siitä vaan enempää mahdu. Bufferia en silti itse oikein koskaan saa täyteen, mutta oishan se toisinaan ihan kiva että pääsis nopsempaa chimppailemaan ja fileiden zoomailut toimis nopsempaa.
kohan
tn1krr kirjoitti:
Jos XAVC S 4k videota tallentuu kortille 83,8 GB 2h 5min aikana niin keskinopeus on n. 11 MB/sec mutta tuona aikana prosessoidaan dataa niin todellisuudessa kirjoittamiseen käytetty aika on jotain muuta.
http://kohan.1g.fi/
Toi kirjoitusnopeus kortille on niin käsi juttu että se on yksi pahimmista Sony-raivareista itelle just nyt. Esim. Kun focus stackaa ruutuja niin olisi kiva nopsaan nähdä menikö oikein siinä välissä. Nyt otat kuvan ja venaat että ledi napsuu aikansa.
kohan
Maffer kirjoitti:Nyt otat kuvan ja venaat että ledi napsuu aikansa.
Itsellä on "Auto Review" pois käytöstä enkä ole hidastelua edes havainnut.
http://kohan.1g.fi/
Öh ei. Ei mulla auto review ole päällä. Vaan kun otan ruudun en voi painaa playta pariin sekuntii kun kamera valittaa että ei voi toistaa.
tn1krr
Maffer kirjoitti:Öh ei. Ei mulla auto review ole päällä. Vaan kun otan ruudun en voi painaa playta pariin sekuntii kun kamera valittaa että ei voi toistaa.
Juuri näin. Tähän törmää pahiten kun paukuttaa AF-C + Eye AF:llä enempi menemään niin punainen valo palaa helposti 10 sek ennenkuin on mitään asiaa chimppaamaan.
kohan
Tässä mallissa ei ole chimppaamisen viivettä.
http://petapixel.com/2016/04/27/leaked- ... thout-lcd/
http://kohan.1g.fi/
Alpine
Viesti Kirjoittaja Alpine »
Firmispäivityksiä, jolla XAVC S:n tallennus SDHC-kortille onnistuu, on julkaistu melko monelle muullekin Sonyn kameralle. Mukana on pokkareita, videokameroita ja 4K-actionkamera.
antnis
Viesti Kirjoittaja antnis »
kohan kirjoitti:Tässä mallissa ei ole chimppaamisen viivettä.
Lcd:t ovatkin turhia kun sitten tarttis käyttää lukulaseja kuvatessa!
